HeaderBorderStyle |
Defines a style for the borders of Legend's header columns. The available options for this property are described on the next table.
Available options for HeaderBorderStyle
Option |
Description |
0 - lbsFlat |
Applies a flat border to the header column |
1 - lbsRaised |
Applies a border raised on its upper left side and a shadow on the lower right side of the header column |
2 - lbsSunken |
Applies a border with a shadow on its upper left side and raised on the lower right side of the header column (default) |
3 - lbsEtched |
Applies a border that looks etched around the edges of the header column |
4 - lbsBump |
Applies a border with a ledge on its lower right side and that looks flat on the upper left side of the header column |
