Picture |
This property specifies a picture (bitmap) attributed to an object. A picture file can be selected in two ways: via Properties List or via scripts, by using the LoadPicture function to specify a file path and name containing a picture. To remove a picture, click the value of this property and press the DEL key. The BACKSPACE key does not remove a picture.
