BackStyle |
This property defines a style for an object's background. Available options for this property are the following:
•0 - fmBackStyleTransparent: Defines this object as transparent, that is, no object background is drawn
•1 - fmBackStyleOpaque: Defines this object as opaque, that is, its background is drawn (default)
NOTE |
This property does no affect bitmap's transparency. Users must use an image editor such as Paintbrush, for example, to save a transparent bitmap. Not all ActiveX objects support transparent bitmaps. |
