<< Click to Display Table of Contents >> ScanTime |
Returns or configures a scan time in milliseconds of a Storage Field, that is, how often a Tag's value is sent back to data compression algorithm, if it is not varying. If this property's value is equal to 0 (zero), the value of the MaxRecTime property is used for the same purpose (default behavior).
