WriteRecord |
WriteRecord()
Inserts a new record on a Database. Values are obtained from current values of each variable specified as data sources for Historic fields. This method is used in two situations:
•To write a new record before the time configured for the next recording when a Historic is enabled by time
•To write a new record when a Historic is disabled
Example:
Sub Tag1_OnValueChange()
' Writes a new record on a Historic
' when a Tag changes its value.
Application.GetObject("Hist1").WriteRecord()
