OpenScreen |
OpenScreen(ScreenName, Arg)
This method opens a Screen inside a Splitter. The ScreenName parameter determines the name of a Screen to open, and users can also specify some properties for that Screen. Please check the Splitter's SplitLink property for more information about the format to specify a screen in this parameter. The Arg parameter allows specifying a value to pass to a Screen via its OnPreShow event, such as in the next example.
Sub Button1_Click()
'Clicking this button opens Screen2 on Test frame,
'a zoom of 100%, without a scroll bar,
'and a default alignment relative to the visible area.
'Also, passes a String to use on the OnPreShow event
Application.GetFrame("Test")._
OpenScreen "Screen2?100?0?0", "This is a test."
Sub Screen2_OnPreShow(vArg)
'This message box displays the sentence
'the sentence "This is a test."
MsgBox vArg
