CanGrow |
Determines whether to apply a stretch effect to the text of a Frame object. If this object's width or height increase, its text accompanies this variation. If this property is set to True, text accompanies variations in object's height and width. Otherwise, this object remains with its initial settings. Default value of this property is True.
