DeleteObject |
DeleteObject(ChildName)
Erases the specified object from a project. The ChildName parameter is a String (ignores capitalization) that indicates the child object to delete. This method returns True if the operation to delete an object was successful, or False in case the child object does not exist.
To delete an object from a reference to an element, use this method in the parent object. Example:
Sub CommandButton1_Click()
Set obj = Application.GetObject("Data")
If obj.DeleteObject("Tag001") Then
MsgBox("Tag successfully deleted!")
Else
MsgBox("Deleting failed: Tag does not exist.")
End If
NOTE |
Only objects with an Insert option on their contextual menu can use this method. |
