Activate |
Activate()
Activates a currently inactive object. Example:
Sub CommandButton1_Click()
Dim obj, tag
Set obj = Application.GetObject("Data")
' Creates a new object and deactivates it (False)
Set tag = obj.AddObject("DemoTag", False)
' Initializes the new object's parameters
tag.Name = "tag001"
tag.Type = 3
' Enables the object (executes it)
tag.Activate()
NOTE |
Activating an object using this method configures the IsObjectActive property of this object to True. |
