SubConditionName |
Name of a subcondition, if it is an Alarm Event. Possible values for this property are:
•DB: Dead Band alarm
•DIG: Digital alarm
•ROC: Rate of Change alarm
•LOLO: Analog alarm on a Very Low range
•LO: Analog alarm on a Low range
•HI: Analog alarm on a High range
•HIHI: Analog alarm on a Very High range
NOTE |
For Discrete-type Alarm Sources, this property assumes the name of the user-defined Subcondition, which is available on the Discrete tab of properties of this type of Alarm. |
If this Event is not an Alarm, this property is equal to an empty String. This is a read-only property.
