AddUserEvent
AddUserEvent
AddUserEvent(Name, [Link], [Type], [ScanTime], [ChangeOnDisconnect])
Adds a User Event to the Collection of Events and returns this object. This method's parameters are described on the next table.
Parameters of the AddUserEvent method
Parameter
Description
Name
Name of this User Event. This is a mandatory parameter
Link
Expression to evaluate in this User Event. This parameter is optional and, if omitted, assumes an empty String. It corresponds to the Link property of a User Event object
Type
Type of User Event. This parameter is optional and, if omitted, assumes the value 0 (zero). It corresponds to the Type property of a User Event object
ScanTime
Time, in milliseconds, to repeat this User Event. This parameter is optional and, if omitted, assumes the value 1000, that is, one second. It corresponds to the ScanTime property of a User Event object
ChangeOnDisconnect
Indicates whether the disconnection is handled as a change on the value of the expression of this User Event. This parameter is optional and, if omitted, assumes the value 0 (zero), that is, False. It corresponds to the ChangeOnDisconnect property of a User Event object
