<< Click to Display Table of Contents >> String |
Read and write property identifying this object, in case the Type property is equal to 1 - nitString. If the Type property is different from 1 (one), reading this property returns an error. Writing to this property always forces the Type property to change to 1 (one). An empty String in this property identifies this object as Null.
