DwordToLong |
DwordToLong(Value)
Converts an unsigned 32-bit value, in the range between zero and 4,294,967,296, passed to the Value parameter to a signed 32-bit value, in the range between -2,147,483,648 and 2,147,483,647, with the same pattern of bits. If the value is in the range between zero and 2,147,483,647, it is returned unchanged.
NOTE |
If the value passed in the Value parameter is a floating point value, only this value's integer part is used. |
