OverrideFillColor |
When the OverrideFillMode property is set to 2 (two) or 3 (three), this property is used to define a color to use when filling moving objects, instead of their original color. In scripts, use VBScript's RGB method to create a color to link to this property. Default value of this property is red (RGB(255, 0, 0)).
