EnableOverrideLineColor |
This property enables or disables this object to override the original color of its image's line by the color defined in the OverrideLineColor property. If this property is enabled, this allows users to modify the original color of this object's line by the color of the OverrideLineColor property. Otherwise, this object displays its original color. Default value of this property is False.
