TransparentMode |
This property specifies a transparency effect mode for this picture. The next table contains possible values for this property.
Available options for the TransparentMode property
Option |
Description |
0 - Disabled |
No transparency is performed (default) |
1 - ByColor |
Transparency uses a color defined in the TransparentColor property |
2 - ByPercent |
Picture remains transparent with a transparency percentage specified in the TransparentPercent property |
Example:
Sub DrawPicture1_Click()
' Leaves the blue color transparent
' when clicking this object
TransparentMode = 1 ' ByColor
TransparentColor = RGB(0, 0, 255)
