Name |
Returns the name of this Connector Point. This is a read-only property.
NOTES |
•The name of a Connector Point may change after inserting or removing Connector Points from a Collection of Connector Points. •The first and last Connector Point in the Collection of Connector Points are named, respectively, as "Begin" and "End". All other Points are named as "PlugN", where N is the index of that Point in the Collection. |
