ConnectTo |
ConnectTo(Object, SlotNameIndex)
Connects this Connector Point to another Screen object, indicated by the Object parameter, and undoes the existing connection, if needed. The SlotNameIndex parameter indicates the index or name where this Connector Point must connect in the Collection of Connector Points.
