NetLibrary |
Configures the type of network library of a Database. The available options are described on the next table.
Available options for NetLibrary property
Option |
Description |
0 - Default |
Default library type |
1 - NamedPipes |
Named Pipes-type library |
2 - TcpIp |
Winsock TCP/IP-type library |
3 - SpxIpx |
SPX/IPX-type library |
4 - BanyanVines |
Banyan Vines-type library |
5 - MultiProtocol |
Multi-protocolo (RPC)-type library |
NOTE |
This NetLibrary property is only available on SQL Server databases. |
