TotalFailedWrites |
Indicates the total amount of operations on .e3o files that failed and were discarded since the database connection was activated. This property can be automatically zeroed in several situations, such as:
•When deactivating the DBServer object
•If the E3DBEngine process is closed for any reason
•If configuration parameters of the DBServer object's connection were changed
