EnableSynchronization |
Indicates to E3, if enabled (True), that it must also perform a data recording on a second database simultaneously, to improve security. If this property is enabled and there is a Standby server, E3 then performs a syncing between databases from both servers. The default value of this property is False, that is, syncing is disabled.
