Style |
Determines a style for a Barcode. The available options for this property are described on the next table.
Available options for the Style property
Option |
Description |
0 - ddbcNone |
Default bar code style |
1 - ddbcAnsi39 |
ANSI 3 of 9 (Code 39) bar code style. Uses letters, numbers, -,*, $, /, +, %, etc. |
2 - ddbcAnsi39x |
Extended ANSI 3 of 9 (Extended Code 39) bar code style. Uses full ASCII characters |
3 - ddbcCode_2_of_5 |
2 of 5 bar code style. Uses only numbers |
4 - ddbcCode25intlv |
Interleaved 2 of 5 bar code style. Uses only numbers |
5 - ddbcCode25mat |
Matrix 25 bar code style |
6 - ddbcCode39 |
Code 39 bar code style. Uses letters, numbers, -, *, $, /, +, %, etc. |
7 - ddbcCode39x |
Extended Code 39 bar code style. Uses full ASCII characters |
8 - ddbcCode_128_a |
Code 128 A bar code style. Uses numbers, punctuation, or letters |
9 - ddbcCode_128_b |
Code 128 B bar code style. Uses Strings, numbers, punctuation, or letters |
10 - ddbcCode_128_c |
Code 128 C bar code style. Uses only numbers |
11 - ddbcCode_128auto |
Code 128 Automatic bar code style. Uses full ASCII characters. Automatically selects codes between 128 A, B, and C to configure the smallest value in the bar code |
12 - ddbcCode_93 |
Code 93 bar code style. Uses letters, numbers, -, *, $, /, +, %, etc. |
13 - ddbcCode_93x |
Extended Code 93 bar code style. Uses full ASCII characters |
14 - ddbcMSI |
MSI Code bar code style. Uses only numbers |
15 - ddbcPostNet |
PostNet bar code style. Uses only numbers and a check digit |
16 - ddbcCodabar |
Codabar bar code style. Uses A, B, C, D, +, -, :, /, or numbers |
17 - ddbcEAN_8 |
EAN-8 bar code style. Uses only numbers (seven numbers and a check digit) |
18 - ddbcEAN_13 |
EAN-13 bar code style. Uses only numbers (12 numbers and a check digit) |
19 - ddbcUPC_A |
UPC-A bar code style. Uses only numbers (11 numbers and a check digit) |
20 - ddbcUPC_EO |
UPC-E1 bar code style. Uses only numbers. Used for UPC zero-compression symbols. In the Caption property, users can enter six digits of a UPC-E code or 11 digits. If an 11-digit code is inserted, then this bar code converts it to six UPC-E digits, if possible. Otherwise, converts from 11 to six UPC-E digits and nothing is displayed |
21 - ddbcUPC_E1 |
UPC-E1 bar code style. Uses only numbers. The width of input data of UPC E1 is six number characters |
22 - ddbcRM4SCC |
Royal Mail RM4SCC bar code style. Uses only letters and numbers and a check digit. This bar code is used in Great Britain |
23 - ddbcUCCEAN128 |
UCC/EAN_128 bar code style. Uses full ASCII characters. This special version of Code 128 is used on HIBC applications |
