OnFetchData |
OnFetchData(eof)
Triggered whenever a new record is processed. This event is used to run a script that modifies field values added to a Report in a script linked to the OnDataInitialize event. Default value of the eof parameter is True and indicates that after the script, the processing of Report's current record was finished.
