MouseDown |
MouseDown(Button, ShiftState, MouseX, MouseY)
This event occurs when any mouse button is pressed on a Screen. Use the MouseDown event to determine specific actions when a user clicks a Screen.
Parameters of the MouseDown event
Name |
Description |
Button |
Displays the pressed mouse button: •1: Mouse left button pressed •2: Mouse right button pressed •4: Mouse middle button pressed |
ShiftState |
Displays the pressed key along with the mouse button: •4: SHIFT key •8: CTRL key •12: CTRL + SHIFT keys |
MouseX |
Displays Screen's X coordinate where the mouse pointer was clicked |
MouseY |
Displays Screen's Y coordinate where the mouse pointer was clicked |
Example:
Sub InitialScreen_MouseDown(Button, ShiftState, MouseX, MouseY)
' Quits the application when a mouse click occurs
' on the InitialScreen object.
Application.Exit()
