DblClick |
DblClick()
This event occurs when there is a left mouse button double-click on a Screen. This event does not occur if that object is not visible or if its Enabled property is set to False. Object's visibility depends on three factors: Visible property set to True, parent object visible, and object's Layer property on Screen's layer.
