Click |
Click()
This event occurs when the left mouse button is pressed on a Screen. This event does not occur if that Screen is not visible or if its Enabled property is set to False. Screen visibility depends on three factors: Visible property set to True, parent object visible, and object's Layer property on Screen's layer. Example:
Sub Screen_Click()
' Displays a message box when
' a user clicks a screen
MsgBox "You clicked the screen."
