KeyUp |
KeyUp(KeyCode, Shift)
This event occurs when a key is released and an object has keyboard focus. Notice that this event is not generated if this object is not enabled (its Enabled property is set to False) or if this object does not have keyboard focus.
Variables of the KeyUp event
Name |
Description |
KeyCode |
Integer identifying the ASCII character of the pressed key |
Shift |
Displays the shortcut key used with the pressed key: •4: SHIFT key •8: CTRL key •12: CTRL + SHIFT keys |
NOTE |
For a list with all key codes available for the KeyCode parameter, please check the article Keys Enumeration on Microsoft Developer Network. |
