HorizontalFillStyle |
Defines an object's horizontal fill. This property works along with the HorizontalPercentFill property, which informs the percentage of an object must be filled. These two properties allow a simulation of a level fill in an object, such as a tank level.
Available options for the HorizontalFillStyle property
Option |
Description |
0 - FillLeftToRight |
Fill percentage is from left to right (default) |
1 - FillRightToLeft |
Fill percentage is from right to left |
2 - FillCenterToEdgesH |
Fill percentage is from center to border |
