Zones |
Defines a set of bitmap images used to create an animation effect on this object. Zone (AnimationZone) objects can be configured by accessing object's Properties window, on its E2Animation tab. The available options for this tab are described on the next table.
Available options for E2Animation tab
Option |
Description |
Zones |
List with all Zones defined on this object |
Add |
Adds a new Zone |
Remove |
Deletes the selected Zone |
Default zone |
Defines the selected Zone as object's default Zone |
Blink |
Defines if a bitmap blinks when this object's value is inside this Zone's interval |
Tip |
Displays a help text about this Zone |
Minimum |
Minimum value for this Zone's variation |
Maximum |
Maximum value for this Zone's variation |
Image file |
Name of a bitmap file that is displayed when this object's value is inside this Zone's interval |
Example |
Displays a preview of a bitmap file of the selected Zone |
