VerGrid |
Determines a type of line to apply on E3Chart's vertical grid. The available options are described on the next table.
Available options for VerGrid
Option |
Description |
0 - Solid |
Applies a solid line on E3Chart's vertical grid |
1 - Dash |
Applies a dashed line on E3Chart's vertical grid |
2 - Dot |
Applies a dotted line on E3Chart's vertical grid (default) |
3 - Dashdot |
Applies a dash-dot line on E3Chart's vertical grid |
4 - Dashdotdot |
Applies a dash-dot-dot line on E3Chart's vertical grid |
5 - Invisible |
Applies an invisible line on E3Chart's vertical grid |
