CopyConfig |
CopyConfig(SourceChart, [Flags])
This method copies settings from an E3Chart to another one. The SourceChart parameter indicates the source E3Chart, whose properties are copied to the E3Chart calling this method.
NOTE |
For Reports, this method works only with Historic-type Pens. |
For example, to copy settings from an E3Chart on a Screen (ScreenChart) to another one within a Report (ReportChart), the following script must be added to the Report object associated to the Report.
Sub OnBeforePrint
Set Chart = _
Report.Sections("PageHeader").Controls("ReportChart")
Chart.CopyConfig(Application.GetFrame()._
Screen.Item("ScreenChart"))
Chart.LoadData()
Chart.FitAll()
NOTE |
This method also contains an optional and not used parameter called Flags, kept only for compatibility reasons. |
