OnFormatCell |
OnFormatCell(Column, FieldName, OriginalValue, FormattedValue)
This event allows customizing the format of the text of E3Browser's cells. The parameters of this event are the following:
•Column: Index of E3Browser's visible column, starting at 0 (zero). It allows identifying the cell's column being formatted
•FieldName: A text with the name of the column's field being formatted
•OriginalValue: Unformatted value of that cell, with a Variant type
•FormattedValue: A formatted value, with a Variant type, according to the configuration of E3Browser's column. If it is modified inside this event, then it allows changing the formatted value
The next example shows the formatting of Alarm fields.
Sub E3Browser1_OnFormatCell(Column, FieldName, OriginalValue, FormattedValue)
If Column = 15 Then
If Not IsNull(OriginalValue) Then
FormattedValue = SourceTypeName(OriginalValue)
ElseIf Column = 9 Then
If OriginalValue = 0 Then
FormattedValue = "High"
ElseIf OriginalValue = 1 Then
FormattedValue = "Medium"
Else
FormattedValue = "Low"
End If
End If
