Enable Script Debugger |
This option enables or disables declaring the hierarchy of scripts for E3 processes. Default value of this option is No (disabled). The available items in this option are described on the next table.
Items available in the Enable script debugger option
Option |
Description |
Enable script debugger for E3Run |
Enables or disables the script debugger for the E3Run process |
Enable script debugger for Studio |
Enables or disables the script debugger for the Studio process |
Enable script debugger for Viewer |
Enables or disables the script debugger for the Viewer process |
NOTE |
The default value for the options described on the previous table is the value defined in the Enable script debugger option. |
