Enable Script Profiling |
Script Profiling is a tool that collects the execution time of each script and displays statistics about the number of executions and the duration of each script. This profiling is disabled by default and, to activate it, change the Enable Script Profiling item.
NOTE |
Script Profiling must be enabled before executing E3Run, E3 Viewer, or E3 Studio. |
