<< Click to Display Table of Contents >> Variables Tab |
This tab allows defining default values for user-defined variables. These variables may also have their values changed at run time by using the SetVariableValue method.
Variables tab
The columns of this tab are described on the next table.
Available options for the Variables tab
Option |
Description |
Name |
The name of a user-defined variable |
A combo box where a value's data type can be defined. The available options are Empty, NULL, Boolean, Char, Byte, Integer, Word, Long, Dword, Currency, Single, Double, Date, Decimal, and String |
