SQL Server Databases
This is a list of all possible errors that may occur when testing a connection to this Database:
ErrorLocal = Open Connection ErrorError #0x80004005 Description:[DBNETLIB][ConnectionOpen(Connection()).]SQL Server does not exist or access denied. (Source: Microsoft OLE DB Provider for SQL Server) (SQL State: 08001)(NativeError:17)
Possible cause
Wrong Server name on a Database Server configuration, or this user has no access to that database.
Solution
Check the server name and if this user has permission to connect to that database.
ErrorLocal = Open Connection ErrorError #0x80040E4D Description: Login failed for user 'WrongUser'.(Source: Microsoft OLE DB Provider for SQL Server) (SQL State: 42000)(NativeError: 18456)
Possible cause
Wrong user name or password.
Solution
Use an user registered on that database or check the password used.
ErrorLocal = ExecuteSql ErrorError #0x80040E14 Description: There is already an object named 'E3Index' in the database. (Source: Microsoft OLE DB Provider for SQL Server) (SQL State: 42000) (NativeError: 1750)
Possible cause
There is already an object (table, key, or index, among others) on this Database with the same name.
Solution
Change this object's name.
