<< Click to Display Table of Contents >> I/O Drivers |
To use bits of an I/O Tag, users must enable I/O Tag's UseBitFields property.
The counting process considers I/O Tags and the size of Block Tags. Bits are not part of this counting process.
Create a Digital Link between this object's ForegroundColor property and the expression TagName.Quality < 192, with its blink option enabled. The Quality property represents the status of Tag's value quality, in OPC standard, and it may vary from 0 (zero) to 255, and that quality is good only above 192.
By enabling Viewer's View communication errors option, on the Communication Errors tab.
Go to Viewer's properties window and change that color on the Communication Errors tab.
