Connections Tab |
The Connections tab allows configuring one or more connections to local or remote Alarm Servers.
Connections tab
Available options on the Connections tab
Option |
Description |
Add Connection |
Adds a new Connection to an E3Alarm. This option corresponds to the Add method of the Collection of Connections |
Remove Connection |
Removes the selected Connection. This option corresponds to the Remove method of the Collection of Connections. NOTE: The Connection created automatically with an E3Alarm cannot be removed |
Connection Name |
Name of this Connection. Press the F2 key to edit this name. This option corresponds to Connection's ConnectionName property on the Collection of Connections |
Domain |
Friendly name to identify the Domain of the selected Alarm Server. This option corresponds to Connection's DomainName property on the Collection of Connections |
Alarm Server |
Name of an Alarm Server, which can be on a local Domain as well as on a remote Domain. This option corresponds to Connection's AlarmServer property on the Collection of Connections. Click |
Connection filter |
Name of a Filter that contains settings for alarm filters, defined on the Filters tab. This option corresponds to Connection's FilterConnection property on the Collection of Connections |
Users can access a remote Alarm Server by simply filling Connection's AlarmServer property of E3Alarm's Collection of Connections with data for remote Domain and Alarm Server, in the format DOMAIN:SERVER, where SERVER is the name of the remote Alarm Server and DOMAIN is the name of a Remote Domain that contains it. To configure a Remote Domain, please check topic Remote Domain on the Domains chapter.
