OPC Folder |
An OPC Folder defines groups or subfolders for a better organization of variables. Each OPC Folder can be renamed as needed, and new Folders can be inserted inside one another. If an OPC Folder is disabled at run time, its whole content is deactivated. To use this resource, follow this procedure:
1.Right-click an OPC Group and select the Insert - New Folder option.
Inserting a new OPC Folder
