Monitor |
The E3 Admin - Monitor window shows real-time information about the status of Domain servers. To do so, right-click the E3 Admin icon on Windows Notification Area and then select the Monitor option.
Available options on the E3 Admin - Monitor window
Option |
Description |
Current domain |
Name of the active Domain |
Ping addresses |
List with all ping server addresses |
Name |
Server's name |
Address |
Server's network address |
Ping |
Shows network ping status with this server |
Clock |
Shows server's local time |
State |
Shows Domain status on the server (Stopped or Running) |
Connection |
Shows the status of the DCOM connection with the server |
Role |
Shows a list of functions reported by the server. Possible values are Active: This is the Domain's active server, Standby: This is the Domain's standby server, Failure(n):The server has local failures reported, Priority: The server requested priority to execute the Domain. This indication forces the active server to switch to Standby mode, Candidate: The server is a candidate to execute the Domain, or E/S: The server contains active IOServers |
