Reproduce the Problem |
Reproducing a problem is the first step to solve it. Once users can reproduce a problem, they can start finding solutions for it. The following questions may give users more insight into the problem:
Users may want to try another application to check if they can reproduce the problem. If they cannot reproduce it with other applications, think about what is specific about this application.
If it does, it may be related to system configuration. Try using a different video driver, or even modifying system configurations to check if this problem persists. It is advisable to have a machine with configurations not much different from the average.
Users can check software version by opening the About E3 Studio item on Help menu. Applications generated in older versions are fully compatible with recent ones. However, applications generated in recent versions cannot be edited or executed in older versions.
