Frequently Asked Questions |
possible reason
Another E3 version is installed and opened while trying to install a new version.
SOLUTION
Close the older version first, and then continue the installation by clicking Retry.
possible reason
An Elipse SCADA version is installed and opened while trying to install E3.
SOLUTION
Close Elipse SCADA and continue E3 installation by clicking Retry.
possible reason
There are two possible reasons:
a)Protection device or detection drivers are not correctly installed.
b)USB port setup is not correct or this port is damaged.
SOLUTION
For each reason, try the following:
a)Execute HaspDinst.exe application with -I option. This can be performed via Run option on Windows Start menu. The command prompt is:
C:\Program Files\Elipse Software\E3\HASP\haspdinst.exe -I
b)Test USB port with another known device, such as a printer. Users can also check on computer settings whether this USB port is correctly configured.
For more information about E3's Demo mode limitations, please check topic Limitations of Demonstration Mode on E3 User's Manual.
possible reason
Path to picture files is incorrect.
SOLUTION
Users must create the same directory structure (the same path) as the original computer.
