Login |
Login([Mode])
This method opens a dialog box for login (user authentication) in an application. The logged-in user remains in memory until another login or logout (user leaving an application) is performed. This method contains a Mode parameter, which is a Boolean determining whether a confirmation or failure message of that operation is displayed (default is False).
Login screen
