CustomConfig |
1.In XControl XC_Pump, select the CustomConfig event and insert the next script.
'Pump's name
PumpName = InputBox("Type a name for the Pump:")
If PumpName = "" Then Exit Sub
'Create an XO_Pump object
Set obj = Application.GetObject("Data.Pumps")._
AddObject("XO_Pump", True, PumpName)
obj.DocString = InputBox("Type a description for this Pump:")
'Link the XControl to the XObject
Source = obj.PathName
2.Save these changes and register the library.
3.On the Screen, right-click a pump and select the Configure option.
