Log Configuration
Log Configuration
Define a Threshold Time for Full Logging Function
Users can define the minimum time to log a function on Full logs (functions that last less than this time are not logged).
Define a Time for Locked Functions Warnings
Users can define a time, in milliseconds, that a function must be executing so that a warning is generated (EcoLogWarning) informing that this function is probably locked.
Enable or Disable Log Sections
Users can define which log sections are enabled. Sections can be subdivided into modules, so users can enable each module separately.
