E3 Server Configuration
Define a Number of Product Key Reading Tries
An E3 Server performs a certain number of protection device's reading tries. If this reading is not successful, E3 is then started in Demo mode.
Disable Multiple CPUs
In case of bi-processed computers, users can configure an E3 Server to use only the first or all available CPUs on the computer.
Define a Ping Time-out
Users can force E3 Server to quickly detect remote E3 Viewer disconnections, interrupting data accumulation to send to an E3 Viewer.
Configure a License Heart Beat
During a connection from a server's license to an E3 Viewer, a keep-alive (or heart beat) is applied by default. If an E3 Viewer remains some time without responding, its connection is automatically closed.
Configure a REC's TCP/IP Port
Users can configure a port number used by the REC protocol. Values between 1024 and 65535 can be used. Values smaller or equal to 1024 are reserved. Null or invalid values enable using the port 6515.
Define an E3Run's Wait Time-out
Users can specify the maximum time, in milliseconds, to quit E3Run.
