Studio
Studio
Fixed the border drawing of the active tab of docked windows in E3 Studio. This bug occurred since v4.0.176.
Fixed a formatting problem in E3 window with a warning to not display the window anymore, when the text was too large. This bug occurred since v3.5.81.
Fixed a problem on the Color Palette window in E3 Studio, which locked the properties list window after closing it. This bug occurred since v2.0.15.
Fixed a problem of not closing the active tab with the key combination CTRL + F4 when mouse was over the command buttons in Organizer, with a docked or floating window. This bug occurred since v2.0.100.
Fixed problems in selection and removal of Screen layers. This bug occurred since v1.18.155.
Fixed the update of Variant-type values when their types are changed via contextual menu (occurred in several locations in E3 Studio). This bug occurred since v1.18.155.
Fixed the position of Text object when inserted on a scrolling Screen. This bug occurred since v3.2.214.
Now the cursor position is correctly updated when using the mouse wheel during the edition of a Text object. This bug occurred since v1.19.87.
In E3 Studio's Screen editor, when pressing ESC during text edition, this edition is terminated instead of interpreted as an unknown character. This bug occurred since v1.20.289.
The WatchWindow window was changed to display common properties of objects, as well as specific properties of the instance. This bug occurred since v2.0.16.
Fixed unexpected closing (GPF) that occasionally happened in E3 Studio when using WatchWindow. This bug occurred since v4.0.121.
Implemented a notification of change on the Screen when moving the Rotation Center, or adding or removing an Anchor point of an object. This bug occurred since v1.18.155.
