Data Server
Data Server
Fixed a bug that caused a Timer Tag's OnPreset event set as a daily trigger (TriggerType = ttDaily) to be called just once. For more information, please refer to https://kb.elipse.com.br/bug0009969-tagtimer-not-executing-onpreset-event-if-triggertype-property-is-set-as-ttdaily/. This bug occurred since v3.0.122.
Fixed a bug that caused a Counter Tag to sometimes skip numbers (for example 1, 2, 3, 3, 5). For more information, please refer to https://kb.elipse.com.br/bug0010248-counter-tags-may-skip-numbers/. This bug occurred since v3.0.137.
Fixed Internal Tag's behavior, which propagated changes in Quality property before updating TimeStamp property when receiving a new value either via Link or via WriteEx method. For more information, please refer to https://kb.elipse.com.br/bug0010635-internaltag-object-propagates-quality-property-before-updating-timestamp/. This bug occurred since v1.21.96.
Fixed an E3Run hanging when a connection to an Oracle database is down while a query to the same database is executing. This bug occurred since v1.18.147 (or earlier).
