Define an Interval Between REC's Statistical Log
This options allows configuring the frequency, in seconds, of REC protocol statistics' log recording. Default value of this option is 300, or five minutes. A value of 0 (zero) disables periodic log generation, and the minimum accepted value is 10. In case of typing a value between one and nine in this field, E3 then uses the value 10.
