Shortcuts |
This option allows executing applications installed with E3 via E3 Admin's contextual menu on Windows Notification Area. The following applications can be executed:
•Elipse Event Log Viewer
•E3 Studio
•E3 Tweak
•E3 Viewer
The Log Viewer item opens Elipse Event Log Viewer, already with the file corresponding to the active E3 log session. For more information about this application, please check Elipse Event Log User's Manual, available via Start - Programs - Elipse Software - Elipse Event Log menu.
If there is a Domain already executing locally, the E3 Viewer item on this menu opens an E3 Viewer to the local Domain. Otherwise, or if the SHIFT key is pressed, opens E3 Viewer's initial screen, where users can select the server and other options, as described on topic E3 Viewer and WebViewer - E3 Viewer Execution - Via Start Menu.
